workhardplayha1ExplorerSep 27, 2014tank drain pipeThe black pipe that drains the gray tank has a small hole in it. Is regular PVC okay to use to make the repair?
Related ContentGrey water tank won't drain completelyHouse battery drainleak at connection to drain pipes and Holding tankKeystone Springdale - Very Low Drain PipesGrey tank ABS pipe leak
