gordinho80's avatar
gordinho80
Tank monitor/Water heater/water pump issue
Water heater, pump, tank level indicators, heater indicator light not working. Dim flash when hitting test. Tried to capture behavior on video in dark...
Test once, all lights dim flash
Test second, All lights dim flash
Turn on heater, heater switch indicator dim flash
Turn on pump, indicator works but pump does not kick on.
Any suggestions? Just spent 3 nights with wife, 5 yo daughter, and 13 yo niece... with no hot water for showers...
  • Well, after digging a little deeper, looks like everything is actually in working order. Battery terminals were loose. So I tightened those down... then realized the breaker inline with the 12v wire was tripped. Reset that. After being all connected properly and hooked up to shore power for a day, battery tested 13.8v and the panel worked. Don't know if the battery will hold a charge yet... will be testing that out in coming weeks. Going to hook up a power inverter to it so I can run my residential fridge while in tow. Will disconnect shore power when I get the inverter set up and see how long the battery runs the inverter for. If we can't get a good run, at least a couple of hours, then I'll look into upgrading the battery. I'm hoping to get at least 5-6 hours of inverter/fridge run time while in tow. Maybe run larger gauge wire with some Anderson plugs to send more juice to the trailer while hooked up to tow rig.
  • Converter is dead so no battery charge or lights when plugged in. Battery is dead because no converter charging it because converter is dead. Everything works when hitched up because the tow vehicle battery is supplying the 12 volts to the trailer.
  • 20 year old camper, with original converter? If so, it may need to be replaced.
    Check output and connections.
  • It should unless the converter or a conection is bad, then it will not supply dc or charge the battery. Now you have to check the converter out put. You have ac power right? So you know power is coming into the camper?
  • Shore power. Battery is dead and awaiting replacement. While hooked up to tow rig, everything works fine. Isn’t the converter supposed to supply 12v to certain things when needed... ie these items ?
