OBSPowerstroke
Apr 03, 2017Explorer
troubledwaters wrote:
While your at it, install Horst Miracle Probes clicky.
If I could access the probes easily, I'd change them out in a second. The problem is the fresh water tank is secured up in the frame by welded brackets and there's not enough room to access the probes with the tank installed. My guess is the tank was installed before the flooring was put down at the factory.
