mkirsch
Jul 11, 2017Nomad II
You can't effectively fill one tank from another. At best you can hope for maybe 1/3 full if that, and then only if you warm the full tank and chill the empty, and hang the full tank upside down over the empty one so liquid will pass, and then I'm not even sure that'll work anymore with the OPD valves.
If you run down the inside tank, I'm afraid removing both will be a necessary evil unless there is alternate access to that inside tank that you don't know about yet.
