sonuvabug's avatar
sonuvabug
TC Battery Replacement - Upgrade Options
Boy when it rains ... it pours. My 4 year old, non-maintenance free Interstate Group 24, deep cycle 12v battery seems to have given up the ghost. It appears to have boiled on the one side and after topping up with distilled water and charging, it doesn't hold a charge and it gets very hot. I'm assuming it's pooched. I'm guessing it needed to be topped up with distilled water before our last trip and it's my fault the level went too low and overheated.
So I'm looking at my options. We are not 12v power users as we usually have 120v plug-in electrical power when we camp. We do not boon dock nor do I see this as a regular thing in our future unless we happen to be travelling through and spending the night off-the-grid.
However, to use the TC's lights, water pump, and to ignite the fridge when rolling or parked, we still need reliable 12v power. My easy to access TC's vented battery compartment is comfortably 14" wide, 12" deep and approximately 12" tall.
I could simply replace the pooched Group 24 deep cycle battery, or upgrade one step to a Group 27 deep cycle battery. I'm also thinking about going to a single Group 31 deep cycle battery as I have the room. My other thoughts are to install two 6v deep cycle batteries hooked up in series that would give me even more power although as you can read from above, I don't really need the extra juice ... or do I?
I also could not find a separate disconnect for the TC's battery (my old Class C had one) so I'm thinking that would be a good thing to install while I'm at it?
What to do ... what to do? Your experience and opinions are welcome and appreciated.
  • Is there a budget you are working with? From the options you mentioned, it seems like you are ready to spend a decent amount of money. Space and weight don't appear to be an issue for you so you have a lot of options.
    I just switched from two 6v Lifeline AGMs with 300AH (~170)lbs to a single 12v 100AH (~30lbs) LiFePo battery from Battleborn. The cost is significant but but space and weight are important factors I had to consider that drove me in this direction. They won't be for everyone considering the cost but still worth taking a look into.
    In regard to capacity, even though I technically "lost" 200AH of rated capacity, in practice it was't more than 50AH because for long life, you want to prevent going below 50% rated capacity on AGMs thus giving my 6v Lifelines a usable capacity of ~150AH. My batteries were also 10 years old so I doubt I was even getting half of that and they didn't hold a charge for longer than a couple of days either.
    I haven't had a trip yet with the new LiFePo but will this weekend. I will be reporting back my experiences to my original thread should you find it of interest to your search.
  • A Trojan T1275 would give you 150 AHs at a 20 hour rate if your energy survey indicates that you don't use more that 75 AHs or so on those days you are not plugged in.
