- covered_wagonExplorer
KIS Man wrote:
Our mattress has low spots towards the center. Would a topper fix this?
I discovered it was the camper sagging under the weight of the mattress and us, the sleepers up there. The bed area has mostly thin framing/ structure, so you'll get some bed sag to the center in lots of these campers.
We folded towels to various thicknesses and laid them under the mattress for a straight bed. This helps a lot but, takes time to get it right. - bigfootfordNomad III
Unfortunately no....
We have this type in our home and camper:
You have to select RV Queen to see the cost etc. You can get an upgraded one that is firmer.
http://www.bedinabox.com/memory-foam-mattress-pacbed-original.html
You can check customer satisfaction:
http://www.sleeplikethedead.com/mattress-reviews-bedinab.html
Jim - trailgranny50ExplorerWe bought a larger size futon mattress with inner springs and topped with memory foam and it sleeps wonderful. It's smaller than a queen but larger than a full size.
- KIS_ManExplorerOur mattress has low spots towards the center. Would a topper fix this?
- Deb_and_Ed_MExplorer III ordered a 4" thick, dense foam mattress topper from Amazon, then trimmed to fit. If I remember correctly, you want foam that's 2.5 lbs per sq ft or heavier if you're using it as a mattress?
- darsbenExplorer IIInstead of a mattress all you may need is a mattress topper. We bought one for every bed we own.
http://www.amazon.com/DreamFoam-Bedding-2-Inch-Memory-4-Pound/dp/B00EQHWCKY/ref=sr_1_3?ie=UTF8&qid=1433077956&sr=8-3&keywords=short+queen+mattress+topper - RoyBExplorer IIIWe added a three inch memory foam topper to our OEM mattress for our OFF-ROAD POPUP tent beds. These can be trimmed to fit any size... The additional three inches just touches the POPUP ceiling when lowered down for travel.
Great sleeping for us...
Roy Ken - bobndotExplorer III
quote wrote:
so I don't knock myself out while trying to sit up in bed
however, if you get a good deal on the thicker mattress........:B
- bobndotExplorer IIIDo you mean a short queen ?
Make sure your rv floorplan allows you remove a mattress easily by bending it. Its sometimes easier to tie or strap it in half lengthwise to remove it and install the new one.
Pay attention to the thickness of the new one so it doesn't interfere with a cabinet or wardrobe door from opening.
compare this link to camping world prices.
http://www.mattressinsider.com/deluxe-rv-mattress.html?&gclid=&keyword=rv%20mattress&matchtype=e?&gclid=&keyword=rv%20mattress&matchtype=e&gclid=COCvh9_768UCFdURHwod-3kAfw - exhaustipatedExplorerA short queen mattress measurement is 60X75 where a queen mattress is 60X80 and can be found on either Amazon or Ebay at reasonable prices. I'm looking for a short queen mattress myself right now and having trouble finding one with a height of 5" as most of them are 8" or 10" since I need to find one that size for cab-over clearance so I don't knock myself out while trying to sit up in bed.
