sleepy
Jul 31, 2014Explorer
If the center of gravity wasn't important it wouldn't be on there. To ignore it would be foolish. It is normally over the axel or up to 12" or so in front of the axel.
It is wrong to tell you that it's not important... knowing from the picture what you have and reading that you plan to tow a jeep with it's additional tounge weight.
You picture shows clearly the effect of the COG being behind the axel.
I would suggest that you visit a good spring shop and get their advice. They are very good at what they do even though the function is akin to a blacksmith shop.
Don't buy a bunch af suspension add ons until you do... you may not need them... if you add them and end up with another truck they'd be wasted money.
You will also need to weigh the front and the rear axel of your loaded truck. That information is criticle with your problem
From appearence... you might have steering and braking problems with the front end being what appears to be that light.
Weigh any advise you get from a forum carefully... get your rig to a spring shop professional.
Sleepy
Sleepy
44,056 PostsLatest Activity: Jan 01, 2026
