SubVet
Jul 31, 2014Explorer
languiduck wrote:
Yes, I'm aware about distributing the weight properly. That's why I asked. I do get what you are saying. But I'm not quite as fearful about liability or getting sued if the little red sticker isn't where everyone thinks it should be. I'm just trying to figure out why it's that way, if it's caused my model truck, if there's anything I can do to change it or counter it, etc.
BTW, I did measure and the sticker is in the correct place. Now once you add in the 2" of those big rubber bumpers in front and the 2x4 I use to shim it back, that has put the sticker arrow a couple inches behind the axle. Thanks again all, I'm going to weight it soon before I worry too much more about it. Frankly, it is what it is at this point. Not willing to change trucks, and a different camper is not an option either. Just going to make the best of it that I can. Need to check out some Brake Buddys I guess...
I think you're on the best track. Get it weighed and see what you've got. You can adjust, somewhat, the actual COG based on how you load the camper. I would only worry if weight comes off the front or if I exceeded the various weight limits (axle, tire, etc.).
BTW I use Torklift's lower StableLoad system and it helped a lot. Both with leveling the truck and minimizing sway.
44,056 PostsLatest Activity: May 04, 2014
