languiduck
Aug 01, 2014Explorer
Carb Cleaner wrote:languiduck wrote:
Unfortunately, I have to set it back or the tail lights will be crushed. I have about 1" clearance there right now.
An inch? Good gravy! You might as well use a 6x6 for padding. I'm thankful that my sewer connection is a 1/4" away from my taillights with a piece of 3/8" plywood between the truck's bed and the camper's rubber bumpers. It's been like that for at least 5,000 miles. Nothing's broken and I can still attach my sewer hose. An inch of space would be luxury. I would think you could gain a half inch, easy.
HAHAHA, that made me chuckle. Still learning, so thanks for that info. Going down the road, I'm worried about the 3" clearance on the cabover and the 1" clearance at the tail lights. I guess I could stand to tighten things up a big then? I can replace the front 2x4s with some 3/4" plywood and see if that helps.
Just to be clear, I'm not obsessing over that little arrow on the red sticker, but I am concerned about it. It isn't but about an inch or 1.5" back from the axle centerline.
44,056 PostsLatest Activity: May 04, 2014
