Reddog1
Aug 01, 2014Explorer II
languiduck wrote:A really true match, a bunch or arm chair experts giving camper advice to a driveway camper. :B
... I will give some airbags a reconsider among other things like flat towing. For now I will take it out at least once before trying to make the correct decision as all I've done is driveway camping so far.
I think you have the right idea. When you actually use your setup, you will be in a better position to accept or reject the many suggestions we have given you. Determine what it is you do not like about the road manors of your truck, and fix that. You may decide it is fine as it is. Each of us have different expectations.
languiduck wrote:I would not be concerned at all. It has a good chance of being incorrect as is most weight decals TC manufactures put on the TCs. My bet is headlights in the tree tops will be the only issue. If you do not mind blinding others, then that will be no issue. As I previously posted, there was never a little arrow on a red sticker on my Bigfoot 11.5 foot TC. :E Should I be concerned? I am not.
Just to be clear, I'm not obsessing over that little arrow on the red sticker, but I am concerned about it. It isn't but about an inch or 1.5" back from the axle centerline.
44,056 PostsLatest Activity: May 04, 2014
