AnEv942
Aug 06, 2014Nomad
Hmm 2 1/2+ of squat in the rear. Least its not unloading by tape 0 on front, may be adding a few hundred. You need to look at other trucks to see what is different & (I think) your missing. But See how she handles on your trip.
Minimum Id go to your Ford dealer or local wrecking yard, pick up rear upper overloads (possible the spring pack), the frame stop brackets, the overload spacer block and longer u bolts. I assume you have lower overloads?
Some other solves
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25225094.cfm
I went out and looked at my trucks tail lights- but its my camper. Hangs down a bit lower so removing taillights wouldnt do anything-still hit sheet metal. Yes, removing would get old-but for grins might be a worthwhile effort just to see. And for extended trip might be worth the effort, if it does anything.
Some other solves
44,056 PostsLatest Activity: May 04, 2014
