languiduck
Aug 25, 2014Explorer
Have a couple good weekends under my belt now. I'm not sure if I'm tying my experience now as a blog or because I think someone might want to read the results. Summary:
Truck is driving and tracking great. I do not feel like any weight is being taken off the front axle. I mean there's 4660# of weight on it so....
Obviously I just over worried a bit on the COG thing because it seems to be centered correctly. I'm not over loaded on either axle.
I do plan to add a front mounted receiver to carry a few things, that should help keep some weight up front and off the back.
Flat towing is great, especially using that Brake Buddy. As long as the Jeep is able to roll on all four tires I'm good. Easy to hook up and go. Generally I'm in a group and between us all we have spare parts to fix any of us. I did find I am throttling back on how hard I push the Jeep on the trails now though. I'm ok with it, in a way it's more relaxing and I'm not beating it up.
I did reconsider the use of air bags. So thank you to those who suggested I take another look. Yes my seat of the pants meter is sensitive and I could tell when I had even a measly 5 psi in the bags on my old truck. I found some Air Lift bags that have an internal jounce bumper and claimed they are designed to be used with no pressure when not loaded. So off came the Roadmaster helper springs and on went the bags. Big differences between the two. The nice cushy ride is gone and the ride with the bags is a bit harsher. But I also am not bottoming out on my bump stops any more either. The bags feel more controlled. There's also a lot less sag, I'm 1.25" higher when loaded (obviously that can change some depending on the air pressure I set it at). Combined with those Torklift Stable Loads it handles everything with ease now. I can probably come off the pressure a little bit. I bought a little $10 12V pump to air up the bags and it's great not having to deal with mounting a compressor on the truck. I have a big portable one in a bag I use to air up the Jeep tires.
Every time I load and unload I find at least one thing I can combine or change to make the process quicker and easier. Like shimming out the front bumpers on the TC instead of carrying around a board.
So thanks again all, things are getting better, I'm feeling more comfortable and figuring it all out. It's been fun. Have another weekend planned over Labor Day. This time I will be unloading the camper at the site. I'll have a new thread to start on the one as I have some new gear to try out that was sent to me.
44,056 PostsLatest Activity: May 04, 2014
