kohldad
Apr 14, 2015Explorer III
I really don't see what there is about strength needed with traveling with a TT that you couldn't do if you think you can with a TC. Even hooking up the equalizer bars can be done with very little effort if you know the proper sequence.
A TC is more about the style of travel and where you can travel versus requiring less strength for setting it up. A lot of folks usually complain and move from a TC to a TT because they don't have the strength/mobility to make the climb into the TC and especially the cab-over.
Now, to answer some of your question.
Some models allow you to just lower to the ground and use off the truck. Others will require you to provide a support under the floor when using off the truck. Even when lowered to the ground, they are usually still about 6" off the ground leaving at least two steps to get into the TC.
For DW and myself, we load up the TC at home, travel for 10 days (hopefully longer soon) and then unload once we get home. Our TC is light enough that driving the truck with or without the camper is about the same. So once we leave, we always have it with us and never unload. But then again, we are not in the same campground for more than a night or two.
44,066 PostsLatest Activity: Mar 14, 2015
