BudDugly's avatar
BudDugly
TC Refrigerator blows 30 amp fuse in truck
I have a 2005 Lance truck camper with a 3-way refrigerator. I've tried using the DC setting twice and both times it caused a 30 amp fuse to blow in my truck's fuse box. It seems I read somewhere that a larger wire may need to be run from the truck to the camper. Any ideas about that?
  • Each refrigerator has label saying the power draw in each mode.
    12V draw is usually in 15-20 amp range, so unless you have bigger than usual refrigerator, something else has to be wrong.
  • My fridge on DC draws between 34 and 36 amps.
    I suggest adding a 2nd charging path direction from the starter battery to the "house" jars and using wire appropriate for 50 amps with a 50 amp automatic circuit breaker.
