bwalton
Mar 31, 2016Explorer
jimh425 wrote:bwalton wrote:
The only TC I can find that allows access with the slides in is the Adventurer 116DS and its access is pretty limited you would almost have to be anorexic to get in and I am not :) are there any others ?
If I was you, I'd look at the actual models in person. Just because I say mine is fine doesn't mean it will work for you.
Slides make all types of RVs smaller inside when they are in, so don't assume an even larger RV like a Class C will be completely usable when the slides are in.
I know that is the case but it is usually not as bad in the Class C's for example, I know the Greyhawks do seem to cut off some use of the kitchen in the front slide models but you still have access to most of the camper.
Its a little difficult for me to drop into the RV store and have a look for some reason the dealers in my area don't carry TC's so unless you happen to catch a used one on the lot your out of luck. The closest RV dealer to me that carries them is 500k so I have to do due diligence online with videos, reviews, etc the final decision would be in person but most of the shopping will have to be done online. .
Thanks
Bill
