gitpicker2009 wrote:
Are you saying you're going to lower the TC onto that for storage?
I'd be VERY surprised if it holds it. Maybe I'm not seeing the size correctly, but unless it's about 4 feet by 7 or 8, I'd be careful as you might end up putting all the weight of the TC on one small footprint area of the floor.
Is it possible that the 800lbs may have been what the unit was rated to carry?
The intent is to take the TC off of my truck and lower it onto the cart before rolling it into the final storage location. This will all be done on the level concrete slab inside my barn. I'll keep the legs an inch or so off of the ground in the event something happens, but that is very unlikely. The cart was used to move a 2600# engine, plus all of the lifting devices and pallets, so I can't imagine the TC overloading it since its dry weight is less than that.
Regardless, and before I actually load it, I will look for a manufacturers stamp to determine what it's load capacity is.
