Geewizard
Jul 29, 2014Explorer
AnEv942 wrote:
Drifting a bit off topic but you lost me geewizard..
Microwave didn't want to work on MSW inverter, so
you install a PSW.
Which solved your problem- installing the PSW or removing the microwave?
That folding panel is very interesting, the compactness & security for storing. Hmm why is convenience so expensive. But as an addon just seems more could be gained.
I set our solar panel up with the intension of adding another panle. But the single generally meets our needs so it moved down the list- but faster recoup times or more amps in would be nice. Because it would have to go toward front of roof-which we at least try to nose in a bit where we can to partially shade camper.
That suitcase just offers some intriguing possibilities, no install, set in the sun- track, especially winter.
But in regards to OP- roof install-its always there, always working. Especially considering the possible needed panels, I wouldnt want to be setting up 200-300 watts worth of panels...
You're right, I drifted. Installing a PSW inverter made the microwave work fine. Then I found I didn't use the microwave very much at all anyhow so I removed it. I kept the PSW inverter. Clear as mud?
44,056 PostsLatest Activity: Nov 19, 2013
