ib516's avatar
ib516
Explorer II
Nov 11, 2018
Tell me your horror stories (Diesel)
Ok, so browsing through the thread about the 2011 Ford diesel left me in shock. Seems like there were many issues with the early builds of that engine. I know the Cummins and Duramax of that generation had their own issues (mostly emissions related?).
How are the newest gen Ford 6.7L diesels holding up (2015+)?
Are their similar stories for the Cummins and Duramax in the latest gen (2014+)? I know the Cummins has been 370hp/800tq for a while (in the 2500), have they worked out the kinks in that one? Are failures common? I only know one guy with a 2014 Ram 6.7L Cummins SRW 3500. He has had plenty of recalls and was losing coolant a while back, but I think that was the famous water pump issue. He has had no serious issues. His is a 370hp/800tq version with a 68RFE auto. But that's a sample of 1 which is pretty meaningless.
I went with a 6.4L Hemi last time I was shopping as it suited my needs better and frankly, I was scared away from diesels (all of them). At that time, my research told me they weren't worth the gamble. What I mean by that is their superior towing performance wasn't worth it to me when they could cost me tens of thousands to repair if they failed, and they were all (my opinion) having reliability issues in the 2011 to 2013 time period. I thought they were mostly pesky ones to do with emissions, but I'm just not into check engine lights on new trucks.
Are the diesels getting better? Should I put them back on my shopping list for my next new truck?
I'll likely be towing under 10k GVW, and it'll likely be a TT around 30'. I do want to log some miles though, and that will include some long distance touring (cross Country type).
  • Not sure if they are 'getting better' The Tier 4 final mandate has added to the complexity and component failure rate of modern diesel engines. No fault of the basic design however.
    Everyone Ford, GM, Fiat Chrysler and even the imports share the same emissions components so failure of those components isn't a brand related thing. More of a lowest bidder thing.
  • y only diesel horror story concerns B20 bio diesel. I store my truck inside all winter and I always fill the fuel tank to the top. Couple winters ago I mad a mistake, used B20 to top it off. Big mistake.
    Over the winter layup it grew algae in the fuel system and a thousand dollars later it was fixed. I imagine if I had it done, would have been 2 thousand bucks.
    Lesson learned, no B20 here again and a fuel stabilizer in the diesel over the winter too.
    Only horror story I have. My ownership has been seamless.
  • wanderingbob wrote:
    As far as up front cost , my $6,000 diesel upgrade , if you access Blue book prices for used trucks will show my diesel should bring a return of 70 to 75 percent of its cost . That is more of a return than the truck itself !
    I think he is asking about repairs and maintenance - not return upon sale. That interests me also. It means nothing to get 75% of its new cost back if you spent 200% fixing it (just an exaggeration to make the difference clear, not saying that's happening).
  • I'll likely be towing under 10k GVW, and it'll likely be a TT around 30'. I do want to log some miles though, and that will include some long distance touring (cross Country type).
    Another 6.4 Ram would work just fine. No DEF, no regen, no complicated exhaust system. And you will have about half the torque of the Cummins but for light loads that should not be much of an issue. Mileage towing (compared to the diesel) will be an eye opener, however.
    Since you asked, I have had three Cummins since '93 putting on over 360,000 miles and, so far, have spent less than $2000 in engine related issues over the last 25 years. The most expensive repair was the radiator fan clutch, a part that cost about $325. Having the torque for towing and the much better fuel mileage towing has more than made up for the up front entrance fee of the diesel.
    The new diesel exhaust systems are not 'grocery getter' short trips, stopping and starting the engine friendly. The engine will need to be run, hard is better, for an hour or so a week to keep the exhaust system happy.
  • No horror stories with my 2013 Duramax, it's been running perfect for 5 1/2 years.
  • As far as up front cost , my $6,000 diesel upgrade , if you access Blue book prices for used trucks will show my diesel should bring a return of 70 to 75 percent of its cost . That is more of a return than the truck itself !
  • In had a 2007 F350 6.0, spent $7000 in one year to keep it runnung. Sold it and purchased an 08 GMC 3500 Duramax, five years ago, and it has been nearly perfect. Today's diesels I would get any one of them, they all seem to doing well. We will more than likely get an F450 with 6.7 for our next truck in a couple of years.
  • I have had five Ram/Cummins pick up trucks .Have drove over one million miles in them .The only problem that I have had that cost more than one hundred dollars was an injector replacement on my 5.9 that cost $1,400.
  • Skip diesels with that light of a load. New diesels will cost you around 7000 dollars up front and more at the pump. With your trailer its just not worth it.
    But, to answer your initial question, other than some emission issues and the crappy CP4 lift pump used by Ford and GM the new diesels are all pretty good.
