dfm
Jun 30, 2013Explorer
Just had to deal with this issue. I tightened the knob too tight and it started to turn inside the plastic knob. I had to cut off the plastic with a dremel to replace the whole knob an screw. I used a needle nose pliers to hold the plate in position to allow for turning in the screw into the plate. reminder don't tighten the tension too much or it will strip the screw inside the plasic knob.
