Fisherman
Jul 04, 2013Explorer
Don't know if yours is the same, mine has the inner and outer main arms, they are about 2 inches wide and an inch thick, the lower slides inside the upper that is attached to the roller. The other one by one square tube with the locking knob slides up and down in very small tracks on the upper arm. Look real close at the lower end of the small track, there is a small screw in each side. Take them out, then the arms come apart and the lock nut for the tension knob can be replaced.
