joeshmoe's avatar
joeshmoe
Explorer II
Apr 09, 2015
Termites in the Camper??
So, in the past, we've had the subterranean variety-the really tough kind to get rid of-and have treated accordingly. For a couple months now, I've been finding wings and some bodies in the driveway and around the outside of the camper. Yesterday, I had the side fridge vent cover off and was cleaning inside when I see several, barely noticeable, teeny-tiny objects scampering around. I look closer...sure enough. Termites! What to do?
I've read about and heard of freezing them, but obviously, that ain't gonna happen this time of year, around here. I've also heard about using pulse voltage (need to unplug or remove all electronics). It's recommend specifically for isolated or limited areas that need to be treated, like a camper, I guess. Anyone dealt with this before?
Even that's an option, how do I keep from re-infestion? They just live in the ground when there's nothing to chew on.
  • Reality Check wrote:
    LMAO..... Now the fun part; ten more answers will follow from people who will determine that DIY experience trumps this.
    Well written sir.
    Bingo. That is EXACTLY why I rarely post here, concerning pests.
    Everybody thinks they know entomology and pest control. It normally is not worth the trouble.
    Thanks for recognizing that.
  • Dog Folks wrote:
    If they are subterranean termites, these could be alates or "swarmers". They are trying to start new colonies. They released into the air in great quantities. 99% do NOT establish new colonies. They are weak fliers, often just being blown with the prevailing wind.
    To start a new colony they need: A high amount of moisture. A rotten piece of wood or very soft soil to dig into. A rotten log or piece of wood that is water saturated, laying of the ground works best.
    As these conditions probably do not exist in your camper, I would do NOTHING with pesticides. They will soon dehydrate and die.
    Simply vacuum them up if you like. I know that they are scary, but the chance of infestation is virtually nil. IF your camper has not moved there may some migrating factors.
    But what would I know? I only spent 35 years in professional, commercial pest control. PM me if you wish.
    Well written sir.
  • Termites should be sitter to get rid of in your camper. Suck em up and fumigate. If they are in fact carpenter ants it takes more but same process and use some diatomaceous earth sprinkled all over inside. It will get spiders as well. Good luck.
  • If they are subterranean termites, these could be alates or "swarmers". They are trying to start new colonies. They released into the air in great quantities. 99% do NOT establish new colonies. They are weak fliers, often just being blown with the prevailing wind.
