Huntindog
Dec 03, 2022Explorer
Reisender wrote:I don't think Pepsi delivers much concrete. They do own Frito Lay, but at least in my area, they all run on CNG, which is pretty clean. The Pepsi trucks are Diesel and they all leave the plant with full loads.JRscooby wrote:Bird Freak wrote:
Sounds good for a local truck but not for cross country.
I don't know about that. Many, if not most, LTL loads move terminal to terminal. 500 miles will most times be near the 11 hour driver daily limit, so terminals are spaced at about that. So spend up to 10 hours charging while trailer is reloaded. Ready for another day.
For sure would not be good for slip-sheet, or even slip-seat operations. Will need to put chargers in parking spots for irregular route operations, but will happen.
Yah good points. As well charging to 70 percent is 30 minutes and that last 30 percent wouldn’t take more than another 45 minutes. My guess is fleet operators will employ them where it makes sense.
As well not all loads will be at max which will extend range. A load of Doritos will weigh a lot less than a load of concrete curbs. As well not all routes have grades like the grapevine that the test trucks did.
We actually see this in real world with our smaller more aerodynamic trailer being towed by our tesla. (Picture below). Ford lightnings are struggling to get 120 kilometers of range pulling bigger heavier boxy travel trailers. We can tow double that range with an SUV that has a 30 percent smaller battery. I’m not knowledgeable about these things but I would assume that some of this physics carry’s thru to the big boys.
Jmho. Definitely not an expert.
Be interesting to see just how they use them.
