Bobbyg2013
Apr 03, 2015Explorer
"test drive"
Before I purchase a TT I want to hook it up to my truck and take it on a short drive on a freeway to see how it handles, etc. Do you think a dealer would allow me to do this?
itguy08 wrote:Gdetrailer wrote:
First mistake is using the supposed max towing numbers in the vehicle brochures.. Those numbers are based on a BASE model vehicle (IE no options and accessories..
It all depends. My F150 Supercrew Lariat, 4x4, Max Tow has 1800 lbs of payload. Very close to the 11,300 that they advertise. At 10% that's 1130 lbs of tongue wright, totally doable with a driver and passenger.25 gallons of fuel will weigh about 200 lbs which leaves you with 1,000 lbs.
Available payload on the sticker assumes a full tank of fuel.
Its all great advice - you need to run the #'s and see where you are at. A properly optioned truck will do what the brochure says. Problem is that they are few and far between.
