Claude B wrote:
@ PUCampain
Note I said the 120V receptical for the washer. If you have an electric dryer DO NOT attempt to plug into it. Electric dryer circuits are 240V NOT 120V. Until as recent as 1996 code permitted the installation of a 3 prong dryer receptical NEMA 10-30 which is a 240V 3 wire (hot / hot / ground). It looks A LOT like a NEMA TT-30r which is the 30A plug for trailers, also a 3 wire but 120V (hot / neutral / ground). With a little effort a it can be made to fit with disasterous results!
This is exactly what I did and it work perfectly well at least, here in Canada.
My dryer is 240V 30 amps so with two 120V hot, one neutral and the ground (4 wires and the electric motor and controls works on 120V). I use an old extension cord 4' long from an older dryer and I baught at Home Depot, a 120V 30 amps RV plug and a metal box. So I use one 120V hot, the neutral and the ground and cap the other 120V hot.
Just plug this adaptor in my dryer plug and my 30' extension of my TT.
Howerver, I don't know is US dryers works only on 240V, electric motor incl.
@Claude B
With a 4 wire it is possible to safely build an adapter, like you have done, but to my knowledge it is not commercialy available, and I would not recommend someone who is not intimately knowledgable attempt it. :)
Up until 1996 in the US it was still permissable to install a NEMA 10-30, which is a 3 wire hot/hot/neutral. It looks A LOT like the TT-30r with a ground on the bottom and 2 slanted blades, and people have been known to with just a little effort force their TT-30r into the 10-30, and zap. There is really no safe way to get 120V from a 3 wire 10-30 receptical due to no ground. Since 1996 all electric dryer outlets are 4 wire like yours, and many older homes are also 4 wire, but there is a distinct possibility of running into a 3 wire NEMA 10-30 on homes in the US.
