Cummins12V98 wrote:
ShinerBock wrote:
FishOnOne wrote:
Also TFL confirmed that the Adaptive Cruise Control was used on the Ram.
I don't think that was in contention especially since it likely would not kick on due to how slow they were going. The ACC only kicks on the brakes if someone is in front of you going slower than you and I seriously doubt there was someone else going slow enough to force the ACC system to kick on the wheel end brakes the whole way down.
I agree!!! some just can't get over the FACT the CUMMINS EB does the JOB far better than the others. The sad part is there is more weight for the fastest instead of the safest!!!
Depends how you look at it. Even if the Cummins was able to hold the weight back on that grade in second gear you have to realize it was in second gear and only had 1 gear left for steep grades. The Ford was in third gear so if I was going to take a 30,000 lb trailer down a 14 % grade I'd be much more comfortable doing it with the GM or Ford from a safety perspective.
