FishOnOne wrote:
ShinerBock wrote:
If you want something with a lot of power and the most up to date tech, then than might decrease its reliability. If you want something that is more reliable with more conservative sustained power output regardless of outside temp, then it might not be the quickest up a hill in all scenarios.
And then you have a 10 speed transmission that applies the right gear for the right senerio which improves towing performance. This also aids in improved fuel economy.
And then you have steel pistons that are designed to handle more heat and cylinder pressure with long term durability.
We'll see once the 2020's get some time and miles on them....way too early to say that there's long term durability there.
