gmw_photos
Jun 10, 2016Explorer
Dodger, just to keep this real, and on topic, consider the following in regards to your comments. You state the above regulation is too long to post here. It is indeed a long document. ( dot 49 cfr ).
I skimmed down thru it, and found the following statements/paragraphs interesting. Quoting directly from the document:
"The TRA asked that special-use tires such as ST, FI, and 8-12 rim diameter and below tires (typically used on smaller, towed trailers) be excluded from FMVSS No. 139..... "
and it goes on in another paragraph:
"Therefore, the agency has decided to exclude bias, ST, FI, and 8-12 rim diameter tires from FMVSS No. 139. These tires, however, will continue to be covered by FMVSS No. 109 and 119. FMVSS No. 109 will not be deleted."
....it is a lengthy document. You might find it interesting reading, if you read all of it.
