pira114
Jun 16, 2016Explorer II
Like I said, I'd be comfortable with either. But there's a reason they make ST tires:
http://m.discounttire.com/dtcs/infoTrailerTireFacts.do
Why Use An "ST" Tire
"ST" tires feature materials and construction to meet the higher load requirements and demands of trailering.
The polyester cords are bigger than they would be for a comparable "P" or "LT" tire.
The steel cords have a larger diameter and greater tensile strength to meet the additional load requirements.
"ST" tire rubber compounds contain more chemicals to resist weather and ozone cracking.
http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=219
"Trailers will be more stable and pull better on tires designed specifically for trailer use. Since Special Trailer (ST) tires are constructed with heavier duty materials, they are tougher than typical passenger vehicle tires."
