gmw_photos
Jun 17, 2016Explorer
myredracer wrote:
Regardless whether or not TT owners should switch to LT tires or whether or not ST tires are substandard quality or outdated design, one big problem as I see it is that nobody tells a new TT owner to limit your speed to 65 mph or to keep the tires inflated to the correct psi at all times and how important it is.
It's not until someone searches on the internet or goes onto an RV forum and sees discussion on ST tires that they learn about how ST tires need to be treated and how they aren't the same as passenger car or light truck tires that people are accustomed to. It shouldn't be that way.
All the more reason to buy a tire that has a higher speed limit rating. As Forrest said, ....one less thing to worry about....
As for inflation, if folks don't have enough sense to keep their tires aired up, then they probably should not even have a drivers license. That is as basic as putting gas and oil in your car.
