4X4Dodger
Jun 25, 2016Explorer II
Huntindog wrote:4X4Dodger wrote:Irelands child wrote:
I don't believe that I have ever seen more truths, half truths and downright incorrect information in any thread on any forum as these 10 pages.
Run what makes you all warm and fuzzy. I like LTs, the guy or two above STs. If your choice is one or the other and that's what you believe, do it but beating this subject day after day with little or no real valid information but hearsay, gut feel or ?? is just a waste of time
If you had read this thread you would have noticed the several posts in which I copied data directly from the NHTSA, the Tire Industry Media and the industry itself.
None of that was hearsay, gut feel or anecsotal.
There is a big difference in believing something just because you "Want" to believe it and beleiving something based on facts. People used to beleive the earth was flat and that the Sun revolved around it. That did not make it a fact.
Yes you did post some stuff. As I told you then, it is incomplete.
IE: you found what you were looking for, and then stopped looking.
Anyone that attempts to read the entire regs better have some time on their hands. It seems that none of the info is in one place. You start reading one page and that page refers you to other subsections which in turn refer you to more subsections etc...
This is not the first time that someone has posted just "part" of the regs.
At one time it was easy to refute all of this as Senior GNC had researched all of it and posted the supporting links. Alas they no longer work as the website has been redone. And nobody has had the time to wade thru it all again to update it.
If I was going to quote some text from Winston Churchills 6 volume History of WWII regarding his correspondence with Roosevelt I wouldnt bother to Post the entire 6 volumes. The same is true here. I posted what was most immediately relevant to this subject. there are reams of unrelated information in the NHTSA Rule CFR49 that has nothing to do with this topic. And thus no reason to post it.
