Cummins12V98
May 08, 2013Explorer III
larry barnhart wrote:Cummins12V98 wrote:NC Hauler wrote:
..Yeah, don't take that the wrong way, the 12 was quite comfortable for a 1 ton dually. I guess like FishOnOne stated, the front suspension may be one reason.
Hey, I noticed something funny about the air pressure recommendations...On the 12', they had loaded cold air psi of front tires at 70 psi and rears at 65 psi...if not loaded, front tires @ 65 psi and rear tires, I believe at 40 or 45psi.. This truck only has ONE sticker with only one air pressure recommendation....80 psi in the fronts and 65 psi in the rears.....nothing for if unloaded...just the one placard... thought it was fascinating.
That is interesting! I have been given******over running 80 in the front of mine and 55 in the rear based on my load.
Are the wheels 17" or did they bump that up? Still Alcoa's?
Did they get rid of the POS general tires?
It's your truck do as you wish. I do as I please.
chevman
Larry,
I was not referring to you.
44,071 PostsLatest Activity: Aug 23, 2026
