Huntindog
Mar 03, 2018Explorer
dodge guy wrote:There is a real good chance I would use it all.sgfrye wrote:time2roll wrote:
I always recommend planning to tow the full GVWR.
Forget dry weight unless you just transport new trailers for a living.
LOL
im still learning weights and specs myself however
thinking this might be simplest, most common sense answer yet
If it’s a trailer with a very low CCC then yes. But as I have said, some trailers are as much as 3-4K lbs. my trailer has a 4100lb CCC. No way I would use the GVWR.
More to the point. If you do not use it all in your figuring.... What is the worst thing that can happen?
And conversly, if you do use it all, and do not figure on it.... What is the worst thing that can happen?
I always figure I will use it all and then some.
Keeps me out of trouble.
44,059 PostsLatest Activity: Mar 18, 2026
