wnjj
Jan 26, 2015Explorer II
DougE wrote:wnjj wrote:
Rear axle torque is what moves the load which is dependent upon, but no where near the engine's torque output.
Not clear. Unless you're running at WOT and torque peak, yes the rear axle torque is not as much as the engine is capable of producing. Assuming a direct gear in the transmission (1:1) and a 3:1 rear end ratio then there is 3 times as much torque at the rear wheel hub as there is engine crankshaft. You gear system multiplies the engine torque.
No where near as in way more. I probably could have worded that better.
44,066 PostsLatest Activity: May 15, 2026
