- notevenExplorer IIIIf a guy measures the maximum suspension travel to the stops there seems to be plenty of daylight to spare... even when jumping like in the commercials...
The system then has those great high wheel humps inside the box... trim them down and they could advertise another 2 cubic feet! - rwjejitsExplorer
gbopp wrote:
It's a place to set your beer, out of the sun, while working on or around your truck.
Winner! - The_Mad_NorskyExplorer
McDonoughDawg wrote:
I find the beds on new trucks to be WAY too far off the ground. You cannot reach over into the truck beds anymore on the half ton's....I don't get it.
Funny how different trucks are from brand to brand and 150/250/350 differences.
I can easily reach into the bed of my F350 dually, and I am vertically impaired. :B
In other words, I'm short. - RoyJExplorerJoking aside, the obvious reason is to compensate for squat under load.
So why do 4x4 sits higher than 4x2, with less load capacity?
Well, the FRONT of a 4x4 is higher to make space for the drivetrain (especially the live axle on Ford / RAM). The rear has to be made higher by leveling blocks to match the front.
So, a 4x2 truck is the absolute minimum height, and a 4x4 is artificially higher for "looks" and headlight alignment. - McDonoughDawgExplorerI find the beds on new trucks to be WAY too far off the ground. You cannot reach over into the truck beds anymore on the half ton's....I don't get it.
- camperforlifeExplorer
APT wrote:
If this is an honest question, then what is "new" and what is "old"? OEMs in the last 10 years are all using 32-33" stock tires, so they aren't growing to fill larger wheel wells. But 20 years ago 29-30" tires were a lot more common on pickups.
Today's pickups are actually lower than trucks 10-15 years ago. Check out the front air dam on a 2014 GM Z71 - hahahaha! Wheel wells are larger though. I believe it is just due to perception of the scale of wheel diameter to wheel well. The black tire disappears compared to silver or chrome wheels and shiny body paint. Trucks have 17-22" wheels vs. 16-17" 10 years ago.
I would argue this. I have had an assortment of 1500's, 2500's gas and diesel since 1972 and my 2wd '11 2500 GMC is the first truck I ever needed a stool to get in the bed. I have hauled 3200lbs in the bed and still had 4" spacing between the rubber stopper and the springs and 10' clearance above the rear tire. The truck is absurdly tall and yes there is enough space to stash a Prius in the fender well. - JwmoehrleExplorerI thought itvwas there to process dear when they ran into the side of the truck, at least that is what happened to my 08 ford. It did not hold up too well, guess a prius would let it last longer.
- campiglooExplorerSrt20. Sometimes U need to hide one of those little fart mobiles until it can be properly disposed of
- RKWExplorer II
kodiakcanuck wrote:
Some great answers in here guys. :B This one is my favourite so farsrt20 wrote:
It's there so you don't damage the box when you "accidentally" run over a Prius and the dang thing gets wrapped up around the tires.
It's funny cuz it's true! - kodiakcanuckExplorerSome great answers in here guys. :B This one is my favourite so far
44,056 PostsLatest Activity: Jan 12, 2020
