Bedlam
Aug 19, 2013Moderator
With SRW you are limited to under 15k lb FW's due to the pin weight. If you are fine with these smaller rigs for full-timing, it will be enough. If you want anything close or larger to this weight, get the DRW so you have reserve capacity and additional stability.
44,059 PostsLatest Activity: Mar 18, 2026
