grizz272's avatar
grizz272
The trials of a nw camper.
Well we went on the second trip with the new camper. The Wife open a cabinet and a box of donuts holes attack her. Hit her in the chest and broke open and dumped on the floor. Of course the loving husband I am I laughed my head off. After picking up the donut holes we opened the bath room and found all the towels on the floor. A modification is do for that cabinet. The last problem is a water problem. We have camped for 11 yrs with a 30gl fresh water tank and never had a problem. Our new camper is suppose to have a 36gl tank. We have ran out of water both times. I intend to put water in to the tank a gallon at a time just to verify we have a 36gl tank.
  • Remember - that 36 gallons includes 6 gallons for the water heater.
  • Maybe your old tt had low flow faucets (aerators) and the new one doesn't.
  • What camper did you get?
    If your water tank is exposed underneath, you can use a flashlight to confirm water level. Try to run it out at home and check the level. Maybe your pickup hose is broken, has a hole, is not on the bottom, etc.
    If you can measure your tank while down there, you can easily calculate the freshwater tank size.
  • You may want to try getting your tires balanced.
    When I went in for this, the tires were so bad (square) that I got new ones....which solved the problem.
