- ret_usnExplorerMy test show the switch will control fan speed in either heat or cool mode with thermostat set on auto fan.
- newman_fulltimeExplorer II
ret usn wrote:
DW says we may use slow speed sometime so that is why I installed the switch. it comes on at low unless the switch is on.
Only tine sliw can be used is in fan only setting - ret_usnExplorerDW says we may use slow speed sometime so that is why I installed the switch. it comes on at low unless the switch is on.
- Old-BiscuitExplorer IIII changed mine out back in 2008 W/O adding the switch...just wired it for HI Speed all the time.
NEVER used LO Speed anyway
