- Janie_RyanExplorerChecked the fuse one more time. That was it. Thanks
- Old-BiscuitExplorer III12V DC power comes from a fuse in DC dist panel
If thermostat display doesn't light then fuse is blown OR t-stat needs reset. - May as well post the brand and model number.
- sdianel_-acct_cExplorerunplug the phone line at the bottom, wait 1 full minute and plug it back in. That worked for ours. Also there is a reset procedure. What brand and model thermostat is it?
- jdb7566ExplorerThere may be a fuse, atc type on the furnace motherboard that you would access from the outside panel. Look for a broken or loose wire.
44,029 PostsLatest Activity: Feb 18, 2021
