Ralph_Cramden
Aug 07, 2017Explorer II
WNYBob wrote:
Here is a photo of the trim I just removed from my TT, it was loose and had cracked caulking along the top of the trim.
The yellowish stuff in the corner of the trim is the bead of caulk, notice it did not make contact with the TT wall! Somehow it did not cause wicking delamination of the wall. I will reinstall with a piece of butyl tape.
This is the second trim piece I have to seal properly! The first channeled water under the TT on top of the poly holding about a gallon of water.
That sucks Bob but out of sight and out of mind is the way these things are put together. You're not supposed to find that sort of BS until it's too late. They did not think you would remove that trim. Do not ever drop an underbelly liner, as your head may explode when you see whats inside there.
More importantly I have a question about your states visited map in your sig. I am trying to figure out how you landed in OH,MD, and VA without touching ground in MI, PA, DE, or NJ? That is a real feat to have accomplished!:B
44,026 PostsLatest Activity: Mar 03, 2025
