bigfootford
Jun 23, 2015Nomad III
Two issues here.
1. No TC shore power...
-- There is a breaker for the shore power in the magnetek. Cycle that and all the breakers. Off and then back on....
--Check your shore power outlet and make sure it has power... Plug a tool in there or something you know works.
2. No house DC.... But the camper battery shows 12.8vdc
Open the door to the fuses and with your meter check the screw that has the big red wire to the other screw that has the Green, black and bare wire on it (DC - or ground as they call it)... You should see 12.8 vdc.
If you do then leave the meter on the ground and check the fuses on at a time. Both sides of the fuse.
If you do not see the 12.8 on the big wire we will have to dig a little deeper in the well.
You might have a stuck relay in the magnetek. But that will not keep the shore power from lighting your night light.
Here is a link to a good start for understanding the wiring of the magnetek.
http://windsurf.mediaforte.com/roadtrek/magnetek/Magnetek_6332_wiring_diagram.html
Jim
Jim
