jmckelvy
Jun 23, 2015Explorer
jefe 4x4 wrote:
The battery is at 12.6 volts now and it's clear that the 2amp charger had no juice and the charge was slowly going down due to the parasitic drag from safety appliances.. So, the question is: shouldn't the 12v circuits work with 12.6 v.even when not being plugged into the 30amp 110vAC?.....
Yes they should but in your case the battery may have been run down from the loss of AC power. Let the battery charge overnight then disconnect AC power and check the 12 volt items for proper operation.
