Old-Biscuit
Aug 06, 2014Explorer III
Furnace needs good strong 12V DC power to operate......fan motor runs on 12V DC,control circuit uses 12V DC to open gas valve and to provide spark.
Which Brand/model of furnace?
Water heater....
Needs good strong 12V DC to operate on gas.
Which Brand/model of water heater?
SOooooooo.....has good is your battery voltage? Have you tested the DC fuses....don't just look test that you have 12V DC on each side of fuses.
The propane detector....fuse pulled because it probably was beeping and irritating previous owner. Check the backside of detector for expiration date..usually 5-7 yrs. so you are due for a new one.
Now sure why it made your propane work.....on a travel trailer they do not trip the propane. Some motor homes have a shut-off solenoid that trips closed when LP Detector alarms. Haven't seen that on a trailer trailer or 5th wheel trailer with portable propane cylinders
You can crack the gas line fitting at furnace/water heater to check that you have propane flow up to them. NO SMOKING/OPEN FLAMES!!!!!!!
After re-tightening fitting...check with soapy solution for any leak
Water heater....
