wincrasher65
Mar 26, 2015Explorer
CavemanCharlie wrote:wincrasher65 wrote:CavemanCharlie wrote:
Thanks for the update. It is weird that they did not label the breakers of fuses. That was probably a oversight on there part.
I , personally , would not like the long tube between the toilet and the black tank. That sounds like a place for a clog. I would be most worried about that.
Sorry I wasn't clear. The black tank is directly below the toilet. The drain pipe runs from the tank about 2 feet to the valve, and then about 15 feet to the discharge port in the bumper of the trailer. It is a large diameter pipe - either 3 or 4 inches. I'm not worried it would clog, but it could leave some stinky debris in that long run if you don't flush properly.
I see. If your not able to use the built in flush a 3-4 gallon (15L) bucket of water dumped quickly down the toilet might do the trick in a pinch.
Probably. Or you can do it the old fashioned way by holding down the foot lever on the toilet and fill the tank/pipe that way.
