DutchmenSport's avatar
Apr 11, 2018
Thoughts? Good, bad, or indifferent?
Late last Summer we replaced our awning. Wind damaged an arm and also started tearing the fabric at one corner where it attaches to the trailer. We had a new one put on (fabric) and the arm was fixed, and everything is happy and well now.
We kept the old awning, as I just don't like to throw anything away. If I can find a way to repurpose anything, I usually do. If not, I'll eventually give it away. So, keeping the old awning fabric was a given.
I had no clue what I'd end up doing with it. I thought about using it as a tarp over my fire wood at home, I mean... all kinds of ideas.
Then, over the winter I thought of an idea.
So, I just tried it this afternoon to see how it would work. Actually, it installed very easy. My wife pulled while I fed it in the awning roller groove. It was slightly breezy, so I held it down with a couple temporary weights.
I kind of felt it was a lot of weight pulling on the awning arms, and if I did this for real, I'd need a better way to secure it to the ground. But, if you saw this set up at a campground, what would you think? Good idea? yes, no, or simply no opinion?
Is this too much weight on the awning arms? Is there a risk of damage if the wind blows up? Would you do this?
FYI, we do have 2 quick shades for extended shade, but this set-up would give us a LOT of privacy behind the "curtain". And, taking it back down was no problem at all. It came down easier than it went up.
Actually, the fabric is so stiff, it's actually harder to unfold it and fold it back up than anything.
Thoughts?
  • I agree about not liking it being solid. Why bother sitting outside if you can't see anything?
    What about using it as a ground rug? Or big pillows for the ground for kids, pets? Or get some pvc pipe and make a dog cot?
  • Kind of Hokey. I don't like the fact that it is solid, therefore you can't see through it.
    As a result of being solid it block the view and is too confining.
    The add a room's are screen that you can see through.
    It will make a better firewood tarp.
  • I don't see any issue, it's really no different than hanging an Add-a-Room or Screen Room off the awning.
