martyn8677's avatar
martyn8677
Thoughts on the Triton V10 Engine
Looking to purchase an F350. I see lots of these engines with fairly low miles. I have heard they are great engines, but get poor gas mileage. Would use to haul my camper and pull a small boat for fishing trips. Would not be a daily driver. Just a play truck.
BTW, my current camper is fairly lightweight.....an Outfitter Apex 8 short bed. About 1800 lbs dry weight. I am looking to upgrade to a single slide camper though at some point.
Anybody had any experience with these engines hauling their campers?
Thanks.
  • Trucks get pretty bad mileage with camper aboard. However, in this area, regular gasoline is quite a bit cheaper than diesel. Assuming the same for you, if the gasoline will do the work and it sounds like it would, I think it would be a good choice. I towed a 4000lb boat quite a lot and it was fine with the Chevy equivalent. Brholt doesn't seem to have a problem with his.
