time2roll
Sep 19, 2017Nomad
Hard to tell from a picture sometimes. What do the others look like?
Tread looks a bit warped like a belt is starting to slip. I would remove the wheel/tire for closer inspection that it is round and shaped properly. Does look a bit more worn on the inside like the camber is off.
No real alignment except to check the axles are square to the hitch and parallel to each other. If an axle is bent it probably needs replaced.
All the tires I have had had wear issues just before coming apart. DURO, Denman and Maxxis. Going to watch the Goodyear Endurance very close.
44,068 PostsLatest Activity: Jun 05, 2026
