jrichard
Sep 20, 2017Explorer
Mine looked very similar to that after approximately 8k miles. A tire shop told me it was normal because of tight turns, backing into spaces, etc. Didn't make sense to me as I'd expect to see the same wear on all sides.
I had an alignment performed at a shop equipped and experienced with that sort of thing (FWIW, $350 in California for two axles a couple of years ago).
I replaced the tires and 9k miles later the wear is perfectly even.
The shop told me they were out of alignment enough to cause the uneven wear and it likely came that way from the factory. Given the **** workmanship on almost all trailers, I don't think there's any reason to believe these things are delivered with proper alignment.
44,068 PostsLatest Activity: Jun 05, 2026
