SoundGuy
Sep 22, 2017Explorer
alboy wrote:
Does it have the wet bolt kit from factory? If not the plastic bushing on the spring hanger bolts some mfg use will wear out and could cause a similar issue.
Last Train wrote:
Good idea . . . I'm going to "assume" ;) that the rig has the original bolt kit as we were the original purchasers and no work as been done on our running gear.
The 192RBS has plastic bushings, no different than most other recreational trailers. Those on my previous K-Z had torn apart and although there was no unusual tire wear as a result I replaced them with a Dexter wet bolt kit. Much less costly are Lippert's Never Fail Bushings so next time I have the bearings done on my own 192 that's what I intend to use instead of wet bolts.
44,068 PostsLatest Activity: Jun 05, 2026
