BobsYourUncle
Dec 04, 2020Nomad
There is a lot more to consider for a 4 season trailer than just dealing with the underbelly.
I was FT for 2 Alberta winters in my 3 season TT, and although an enclosed heated underbelly would have helped, there were a lot of other issues too.
In the minus 30s C, I literally had frost building up on the inside walls in some places. I had to throw a lot of heat at it to keep it liveable. I went through a lot of 30 pounders. Gets expensive.
Water lines that run inside the trailer are typically in the back of closed cabinets. It was a full time fight to keep my water running.
I had to leave cabinet doors open and run electric heaters aimed inside to thaw frozen pipes.
Dump time was no picnic either. I had to leave a radiant heater under my dump pipes for hours just so I could pull the gate valves and empty the tanks.
Another consideration was my propane tanks. In minus 30 temps the furnace ran a lot and the flow would reduce to a slow trickle. A heating pad between the tanks helped a lot.
The windows were caked with ice. Had to block various outside hatches from cold air entering. Had to cover a few windows with foam to try to keep heat in.
The fridge packed it in, too cold, and after many little fixes like a light bulb in the back (Thanks Don for that one) I wound up buying a small bar fridge to hold me over until spring when I pulled the fridge and got it going again.
But!! It was a blast! I enjoyed the challenge of being FT in freezing Alberta winters! Great memories! And a few stories to go with it... :B
