ShinerBock's avatar
ShinerBock
Threshold for Pain: How much can your diesel take?
Recently Diesel World Mag made a few articles about how much each diesel can handle, but never ended up posting the Cummins numbers. Drivingline, an autoblog owned by Nitto, just finished up a similar series of how much each diesel has been known to handle and what their weak link is. This time, they posted all of the diesels.
***Please note: These power numbers are for engine only assuming all supporting mods(i.e. driveline, trans, fuel delivery) are capable of handling these power numbers. So yes, a stock trans will blow long before you hit these numbers.
What is also interesting, and contrary to what many here believe, is how well a diesel engine will hold up to high power numbers with proper tuning. With the advent of common rail and electronically controlled injectors, many novice tuners added too much fuel and timing down low causing too high of cylinder pressures which is very hard on engine internals. This caused many horror stories and many internet myths. Cutting back on fuel and timing at low rpms and increasing it as the rpms rise is much better for your engines internals as the articles state. And of course these are all rear wheel numbers which are generally about 15% less than crank numbers.
THRESHOLD FOR PAIN: POWER STROKE EDITION
7.3L Forged Rods (94.5-00)
Threshold for Pain: 600 HP (1,100-1,200 LB-FT)
Weak point: Rods
7.3L Powdered Metal Rods (01-03)
Threshold for Pain: 450 HP (850-900 LB-FT)
Weak Point: Rods
6.0L (03-07)
Threshold for Pain: 800 HP (1,300-1,400 LB-FT)
Weak Point: Rods
6.4L (07-10)
Threshold for Pain: 900+ HP (1,500-1,700 LB-FT)
Weak Point: Pistons
6.7L (11-Present)
Threshold for Pain: 700 HP (1,300-1,500 LB-FT)
Weak Point: Rods
THRESHOLD FOR PAIN: DURAMAX EDITION
LB7 (01-04)
Threshold for Pain: 550 to 600 HP (1,100-1,200 LB-FT)
Weak Point: Rods
LLY (04.5-05.5)
Weak Point: Rods
LBZ (06-07)
Threshold for Pain: 650 HP (1,200-1,300 LB-FT)
Weak Point: Pistons
LMM (07.5-10)
Weak Point: Pistons
LML (11-16)
Threshold for Pain: 700 HP (1,200-1,300 LB-FT)
Weak Point: Rods
L5P (17-Present)
Threshold for Pain: Not yet known since no one has been able to crack the ECU yet
THRESHOLD FOR PAIN: CUMMINS EDITION
5.9L Mechanical (89-02)
Threshold for Pain: 800 HP (1,400 to 1,600 lb-ft)
Weak Point: Rod Bolts
Threshold for Pain (Race Applications): 1,400 to 1,500 hp due to running at higher rpm's
5.9L Common Rail-6.7L (03-Present)
Threshold for Pain: 900 HP (1,800 lb-ft)
Weak Point: Rods
